Heating Belt for Brewing
Discussion in 'General Electronics Discussion' started by Podtheblade, Jun 5, 2019.
  1. Podtheblade
    Podtheblade
    3
    Jun 5, 2019
  2. Minder
    Minder
    2,948
    623
    Apr 24, 2015
    If only 30w you could use one of the dimmer style controls.
    A ceiling fan version should work at that wattage.
    M.
  3. Bluejets
    Bluejets
    3,991
    824
    Oct 5, 2014
    Says in the description below the purchase item you can regulate the temp.
    The heat can be regulated by moving the brew belt higher or lower on the vessel.
  4. Minder
    Minder
    2,948
    623
    Apr 24, 2015
    I built myself a brewing cupboard from an old packing crate, holds up to four carboys.
    A slim under desk leg warmer panel was used to heat it, this is a very thin glass fronted low wattage heater unit.
    The heater is controlled by wiring up to a ordinary wall mount heating thermostat.
    Works great.
    M.
  5. Podtheblade
    Podtheblade
    3
    Jun 5, 2019
    Hi Minder
    I see some on ebay for 220V will these work in the UK on our 240 V mains system ?
  6. Minder
    Minder
    2,948
    623
    Apr 24, 2015
    They should be OK, they are not made to that close of tolerances.
    The normal industrial standard is +- 10%.
    It has been some years, but isn't UK 230v now?
    M.
  7. Podtheblade
    Podtheblade
    3
    Jun 5, 2019
    Thanks Minder i have ordered a couple of these.
    Really appreciate your advise
    Thank you
    Paul
  8. duke37
    duke37
    5,341
    753
    Jan 9, 2011
    The UK used to be 240V and some european countries were 220V.
    The UK has not changed in practise but follows the european standard which is now
    230V +10% -6% that is 216.2V to 253V
    I get 240V consistently
    Presumably the standard was made wide enough so that no distribution equipment needed to be changed.
  9. Harald Kapp
    9,891
    2,096
    That's it.
