heathkitt temp sensor diagram lm35dz trans
Discussion in 'Sensors and Actuators' started by Henri, Mar 8, 2016.
  1. Henri
    Henri
    Mar 8, 2016
    Good evening,i have bought a heathkitt 4001 model at a radio fleemarket with out a temprature sensor,what tipe of transistor can i use and would like to know where to connetc wires,best wishes-Henri ,south africa....
  2. 73's de Edd
    73's de Edd
    2,939
    1,246
    Aug 21, 2015
    That "transistor" is in reality, being a complex integrated circuit in a micro packaging. Research that number on Google and see what you REALLY have there and where in South Africa that you can find one.
    It's not going to be on the shelf at a local market.
    Considering that the unit IS EVEN BEING BAD.
    As they readily don't test unless you measure related voltage/temperature shifts while being in its designed circuit.
    73's de Edd
