Heathkit ID-4001 Weather Station
Discussion in 'Electronic Repair' started by Elephant, Feb 13, 2005.
  1. Elephant
    Elephant Guest
    Last night before I went to bed, the weather station was functioning
    normally. When I got up, the display was dead, except for a few digits
    that were dim.
    I unplugged it for about 30 mins. Upon powering back up, everything
    seemed to run normally, except for the barometer display. Only 3 digits
    light up, and those are dimmer than the rest.
    Otherwise, it's keeping good time. Wind speed and direction is ok as
    well as the in/out temperature.
    Before I really get digging into such an old unit, has anyone run into
    this before? I'm thinking the micro-processor is ok since everything
    seems normal except the barometer.
  2. NSM
    NSM Guest
    On some of the Heath lists there are discussions. Someone actually makes
    some new parts for these.
  3. Phil Bowser
    Phil Bowser Guest
    Isn't this unit backlit with a flourescent tube (standard 4W or 8W)? I
    had one that the lamp would fail fairly often, and you want to replace it
    right away, or it will overheat the ballast supply circuit, and ruin parts
    there...
  4. James Sweet
    James Sweet Guest
    Sounds like he has the lower end unit with the LED displays.
  5. JMK
    JMK Guest
    jan piste kronlund at tuubi1 piste net
    Please notice my new address!
    Osoitteeni on muuttunut, oikea on yllä.
    The 4001 is with LED's and the 5001 is with a backlit LCD display.
    Ask this guy, he has worked a lot with Heathkit : http://www.d8apro.com/
    Jan
    Finland
  6. Elephant
    Elephant Guest
    Thank you for the link. This is just what I'm looking for
  7. JMK
    JMK Guest
    Your welcome, hope you get it fixed!
    I got one too, nice unit ;-)
    Jan
    Finland
