Heathkit clock speaker?
I
ian field
Franc Zabkar said:
Neither of the clock circuits makes any sense to me.
Your clock has a 25VDC supply which, at a 50% duty cycle, would cause
a 41.5 ohm speaker to dissipate 7.5W.
In the OP's clock circuit, a 41.5 ohm speaker would cause the 150 ohm
1/2W resistor to dissipate ...
(18/191.5 x 0.5) x (18 x 150/191.5) = 0.66W
I can only assume that the speaker's impedance at the operating
frequency of the alarm is *much* higher than one would expect. For
example, at 1kHz an impedance of 100 ohms would require an inductance
of 16mH. I measured the inductance of an 8 ohm 1W 3" speaker on my
DMM's 2mH scale as 0.08mH and about 0.5mH on the 2mH and 20mH scales.
I could hear a high pitched tone on the 2mH range (1kHz ?) and a low
pitch on the 20mH range (100Hz ?).
This site appears to be dedicated to saving and restoring old Heathkit
clocks:
http://www.decodesystems.com/heathkit-clocks.html
Here is some info on the MK5017 clock chip that was used in the
GC-1005:
http://www.decodesystems.com/mk5017.html
The MK5017's Tone output is shown driving a 2N3904 transistor
connected to a 17VDC supply through a transformer-coupled 8 ohm
speaker:
http://www.decodesystems.com/mk5017-2.gif
The transformer is spec'ed as "2K/8R".
I'm really clutching at straws now, but is it possible that the
Heathkit speaker has a built-in 2K/8R transformer ??? Does it have the
usual permanent magnet? Would it make sense to have a stationery 2K
winding and an 8R moving coil on a soft iron former ???
Finding a way to reduce the duty cycle might be a means to get away with a
more commonly available lower impedance speaker.
F
Franc Zabkar
AFAICS, at 25VDC a 40 ohm speaker would draw 600mA when the transistor
switches on, regardless of duty cycle, assuming the transistor has a
high enough gain at whatever base drive the IC provides. An MPS-A20
transistor is only rated for 100mA.
- Franc Zabkar
I
ian field
As the speech coil is an inductor it will exhibit a linear rising current
waveform from the initial application of voltage, obviously that will be
shorter for a lower impedance/inductance speech coil so the pulse width must
be made shorter to ensure it terminates before the inductor saturates.
F
Franc Zabkar
If my inductance measurements make any sense, then the time constant
of the speaker would be L/R = 0.5mH/40R = 12us, or 80uH/40R = 2us.
That's a very short pulse.
- Franc Zabkar
F
Franc Zabkar
I used Bob Parker's ESR meter to measure various 8 ohm speakers. AIUI,
the meter delivers 8us pulses to the device being tested.
FWIW, here are my results:
10W/8R - 35 ohms
2W/8R - 22 ohms
0.5W/8R - 15 ohms
20W/8R/20kHz tweeter - 18 ohms
- Franc Zabkar
F
Fred McKenzie
Joe said:
I actually built this thing circa 1980, and still use it. I recently
found pdf's of a manual and circuit diagram for it at
http://www.pestingers.net/Heathkit_manuals_sequential.htm
A quick look at these pdf's didn't tell me any specs for the speaker,
tho.
Joe-
Back in the 70s I built a kit clock using parts and instructions from
Radio Shack. The specified 8 Ohm speaker was driven through a 100 Ohm
series resistor. I found a small 100 Ohm speaker, and figured I might
get more power transfer if it matched the resistor. The result was
definitely louder than the original 8 Ohm speaker.
I didn't try it without the 100 Ohm series resistor, which would be
similar to your configuration. Suppose your square wave was 10 V RMS.
As an approximation, that would produce one watt into a 100 Ohm speaker,
which is probably louder than your neighbors would like!
I still have the old clock and have enhanced it over the years. It now
has a 9 volt battery backup with its 60 Hz signal coming from an
oscillator that divides down a color burst crystal tuned to 3.579540
MHz. The frequency may drift a bit, but it doesn't stop when the power
fails.
Fred
