Heater element continuity test with multimeter
westrock
May 14, 2013
3
May 14, 2013
3
I have an LG dishwasher (model LDS5811WW/02) that is throwing an "HE" error code. According to LG the error code indicates a bad heater element or heater circuit. I pulled the heater element and checked for continuity at the leads of the heater element with a multimeter. The continuity test was negative; there was no reading for a continuous circuit. I checked the heater element at points behind the mounting plate (see pic) and at that point there was positive continuity so I'm wondering if the element is bad or not. The leads look in good shape with just a little rust, and the element looks sound.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
No point testing the outside of the heater. Check for the resistance between the two power connectors.
There is also a possibility there is a connection between these and the case (and that would be a bad thing).
The reason for the error code clearly indicates that the driver circuit for this may also be the fault. That may be harder to check.
CocaCola
Apr 7, 2012
3,635
Apr 7, 2012
3,635
You can 'idiot' test the element, strip the wires on a cheap extension cord and attaching them to the power connectors (spade connectors with yellowish ceramic on each side of the unit) with some tape... Place the element in a frying pan or on a non-flammable surface and plug it in for a bit... It should heat up in a few seconds, if not it's broken...
And play safe, don't burn down the place, that element will glow red doing this 'idiot' test, don't be an idiot...
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
I don't think you need to test the element any further. That test should suffice. It's open.
Chris
westrock
May 14, 2013
3
May 14, 2013
3
Chris
The element is bad, as the continuity test indicated. There is an internal fuse in these elements that fails and you have to replace the entire element, so I had to order a new one.
