Gristle McThornbody
- Mar 14, 2012
- 31
- Joined
- Mar 14, 2012
- Messages
- 31
I plan to build a power supply based on a LM732 voltage regulator driving a couple of
2N3055's. This supply is targeted at 24 vdc at upwards of 10 amps, but I am making it adjustable.
I am more familiar with small power regulators where any excess voltage in the supply has to be dumped across the regulator (along with the accompanying heat). With a LM732-type design, is this still an issue? If I supply, say, 30 volts to the regulator (max input is 40), and my output voltage is dialed down to 13 volts, will all that power/heat have to be dissipated, or does this type of design have to deal with that problem? TIA
