heat from sawdust?
Discussion in 'Home Power and Microgeneration' started by Neil Adamson, Apr 10, 2004.
  1. Neil Adamson
    Neil Adamson Guest
    Hi
    I have sacks of sawdust to get rid of from my workshop - Is there a
    practical way of getting heta from it for my greenhouse & maybe the home? -I
    thought of maybe producing gas from it but am not sure how to go about it.
    thanks
  2. Dale Farmer
    Dale Farmer Guest
    If you are already burning wood, scattering handfuls of it onto the fire
    whenever you walk by is about the easiest method. Commercial producers
    of sawdust will compress it into fuel pellets for pellet stoves. I have no idea
    if that is practical on a small scale. You can also use it in your garden and
    landscaping as a ground cover in the fall.
    --Dale
  3. Nick Hull
    Nick Hull Guest
    You could mix it with a bit of petroleum like an artificial log
  4. ptaylor
    ptaylor Guest
    But do be careful!,I've heard sawdust can be explosive,similar to grain
    dust,etc.
  5. david
    david Guest
    you could also invest in a presto log machine and make logs from it
