Heat batteries
Discussion in 'General Electronics Discussion' started by Jameskennymatheson, Apr 10, 2021.
  1. Jameskennymatheson
    Jameskennymatheson
    5
    Feb 18, 2021
    Heat a battery Sustainable energy
    Hi
    I am trying to find a thermal fuse with a 40c(or35c) open and 50c(or55c)close I can put on a lithium ion battery to keep the battery at that temperature range
    It is for a sustainable heating project
    Please tell me your thoughts if that's possible
    I've read lithium ion batteries are recommended to be less then 55c when charging
    Thanks for letting me ask
    This project will help tremendously if it works
    I understand it is not recommended and will not in anyway blame you if there are any problems that happen
    <SNIP>
    The use of a lithium-ion battery is possible in a temperature range of 10°C to +55°C. However, the charging should take place only at a battery temperature of +5°C to +45°C. The deal temperature range of the batteries is room temperature
    Mederators note : removed email to avoid spam and privacy
  2. Alec_t
    Alec_t
    2,956
    803
    Jul 7, 2015
    Google 'resettable thermal cutouts'. Do you also have a suitable battery management system to prevent over charging and discharging of the battery? That is important, as lithium batteries can catch fire or explode if not treated properly.
  3. Jameskennymatheson
    Jameskennymatheson
    5
    Feb 18, 2021
    That's why there is a thermal fuse
    So it doesn't explode
    So far everyone told me it will work and I should make it myself
    I.dont have fuses and I need.help finding a 35c open and 55c close fuse or 35c open and 50c close
    If you can help me locate the thermal fuses
  4. Bluejets
    Bluejets
    4,839
    1,014
    Oct 5, 2014
    Forget it.
    You have you sensing A-up.
    The BMS units sense voltage /current levels and take appropriate action long before any thermal device would activate.
    That's why it's called a BMS.
  5. Audioguru
    Audioguru
    3,310
    703
    Sep 24, 2016
    A Lithium battery is sealed and over-charging or over-discharging it is dangerous because the heat produced causes pressure to build up inside it. Then Ka-BOOM!!
    Why don't you use the battery or its charger to power a heater instead??
