Health Hazard ?
Discussion in 'Electronic Basics' started by [email protected], Dec 24, 2005.
  1. Guest
    Hello members, I am confused whether PCB (Printed Circuit Board) also
    known as Polychlorimated Biphenyls can cause cancer. Dear members any
    comment on this ?
    Regards.
  2. Tom Biasi
    Tom Biasi Guest
    Its Polychlorinated Biphenyls , if you are going to troll at least spell
    correctly.
    Merry Christmas,
    Tom
  3. Pooh Bear
    Pooh Bear Guest
    They aren't the same thing at all.
    The 2 things simply share the same acronym.
    Graham
  4. Jasen Betts
    Jasen Betts Guest
    Polychlorinatedbiphenyls have a bad reputation, for all I know it's
    justified.
    I don't think printed circuit boards contain polychlorinatedbiphenyls,
    even the "phenolic" type of printed curcuitboard.
    the do howerver contain PBDE
    Poly Bbrominated Diphenyl Ethers or something like that
    http://inchem.org/documents/ehc/ehc/ehc162.htm
    Burning any organic substance (even tobacco) releases dangerous toxins,
    so if you do that avoid the smoke or preferable use a high temperature
    furnace that can consume the combustion products fully.
    Bye.
    Jasen
  5. Pooh Bear
    Pooh Bear Guest
    So-called 'phenolic' boards are a misnomer. It's how they *were* once made.
    A more modern acronym for them is SRBP - meaning 'synthetic resin bonded
    paper'. ( synthetic resin = epoxy glue ).
    Graham
    The *do* stink when burnt though. I don't think it's especially harmful.
  6. Rich Grise
    Rich Grise Guest
    Oh, no worries there - I'm meticulous in consuming all of my combustion
    products! %-}
    Cheers!
    Rich
  7. Dan Fraser
    Dan Fraser Guest
    Those are two different things that have the same acronym. They are not the
    same.
    Dan
  8. Rich Grise
    Rich Grise Guest
    What things? A post like this with no context makes no sense.
    Rich
