Headset cable bitten through
Discussion in 'Electronic Repair' started by Lewin Boehnke, Mar 10, 2007.
  1. Hi,
    my dog bit through my headset cable (Trust Multi Function Headset 310) which
    I now try to fix.
    The headset cable consists of three cables (correct term??) each of them
    consisting of two leads which seem not to be isolated against each other (I
    know they somehow have to be, this is one of my questions). The leads are
    wrapped around a white fibre that i guess is there for stability.
    All of this should be visible on this photo:
    http://www.lvboehnke.de/kabel.png (160kB)
    How are these leads isolated against each other? Is each core of each lead
    isolated and if so, how can i repair it?
    Thank you very much in advance
    Lewin Boehnke
  2. colin
    colin Guest
    hard to tell, but the bit in focus looks like its just 'figure of 8', with 2
    cores,
    the black plastic outer should also go be between the 2 conductors.
    you can cut the black plastic between the two conductors and you should see
    it goes between them.
    you just have to cut it back a bit and insulate it with pvc tape maybe.
    not sure what the white fibre is for unless you say for support,
    it does look suspiciously like coax cable however.
    Colin =^.^=
  3. Lousy photo but it looks like twin shielded coax to me. If not then it's
    just two insulated cores in each lead.
  4. Eeyore
    Eeyore Guest
  5. Sorry,
    I don't know how this happened. Use http://www.lvboehnke.de/kabel.jpg
    instead. It is 44kB. I will post better images this afternoon.
    Lewin Boehnke
  6. PhattyMo
    PhattyMo Guest
    That's commonly used in headphone cables..
    It's basically a small Litz wire,I think. Each 'wire' is a bunch of
    smaller strands that are coated with varnish/insulation. (notice how one
    wire is *blue*? copper wire isn't blue.) Then both strands are run
    through the same outer sleeve.
    The fiber is the center is just that,A fiber..It's to give the cable a
    bit of strength,and tension relief,if you were to accidentaly yank on
    it,it (hopefully) won't snap those little wires.
    Repair? Some solder,and tiny heatshrink tubing?
    It might take a bit of practice,the insulation on that wire is kinda
    tough,and it's hard to get it to tin sometimes..
  7. What you are describing is 'tinsel wire' - used for flexibility. It is often
    used for shavers (2 core).
  8. Trust Multi Function Headset 310
    Show us photo of more of the cable. Show connector(s). The description says
    that it has "connectors" (more than one). Where is this cable broken?
    I suspect that this is only a 2 conductor cable, not 3 or 4, from the
    description. But maybe not...
    More photos and information would help.
  9. It would also be helpful if you'd open the headset where the cables make the
    connection and either describe or photograph the connections. Knowing where
    the damaged cables connect would be helpful information.
  10. Jack
    Jack Guest
    Lewin from experience. These internal cables are insulated by a thin
    layer of enamel.
    Very poor way of insulating wires from each other, but it works.
    The fibre center is for strenght.
    Head phones like these are usually throw away item headphones.
    But if you wish to fix them just join the wires, insulate them using
    heat shrink available from any electronics hobbyists store, and kick
    your dog when you get frustrated.
    Probably a good lesson re the dog. Keep him away from things he
    doesnt know about. He doesnt listen to radio.
