Headphone output current
Discussion in 'Electronic Design' started by Tim Kendall, Jun 19, 2007.
  1. Tim Kendall
    Tim Kendall Guest
    I want to use the headphone output from an MP3 player to drive a
    homemade audio amp. How can I be sure I do not damage the headphone
    output by drawing too much current?
    Tim K.
  2. Normally this would not be a problem, as headphones are about 32 ohms
    impedance, and your homebrew amplifier should be a much higher
    impedance, say 10000 ohms.
    But if you get your amp design wrong, I would suggest a series
    resistor of say 1Kohms in series with a nonpolar capacitor of 47uF
    63V, to protect your MP3 player
    martin
  3. Eeyore
    Eeyore Guest
    Well you won't.
    An amplifier's input has a higher impedance than your headphones so it'll draw
    *less* current. And yes, that's safe.
    Graham
  4. Meat Plow
    Meat Plow Guest
    That won't happen. More likely damage the input of your amp unless you
    designed it to accept signals of a 1000mv or so.
