Headphone Jack problem
Discussion in 'Electronic Repair' started by MarkyT, Jan 9, 2005.
  1. MarkyT
    MarkyT Guest
    My Labtec headphones will no longer work if the plug is pushed all the
    way into the jack on my sound card. When it's pulled out a bit, it
    works but there is static in the background when there is no audio.
    The odd part is that this will happen even with an extension. With the
    extension cord plugged properly into the sound card and the headphone
    plugged into the extension, no sound. Pull the headphone plug out
    slightly on the extension, I get sound.
    What is causing this?
    Thanks!
    Mark
  2. Kevin R
    Kevin R Guest
    try your head phone in something else then you will know which is causing
    the fault
