doug young
- Mar 23, 2016
- 2
- Joined
- Mar 23, 2016
- Messages
- 2
I bought a little amp on Amazon a Pyle PLMP 35. I want to use it to amplify some headphones. I connected a 3.5mm stereo female jack to the speaker output terminals (one negative and one positive for each channel), which requires a common ground for both channels. When I do that, I get distortion and interruptions at low volume, and pretty poor quality at higher volumes. The power LED also flashes at low volumes. If I connect only one channel at a time, it sounds OK, not great, but OK on that channel. Shouldn't I be able to connect the grounds in common to the speaker outputs?
If not, what do you recommend? I cannot separate the grounds on the headphones because they are wired together at the male 3.5mm jack.
Incidentally, the input for this amp is a 3.5mm stereo female, which of course has common grounds for the stereo channels.
This is the 2d one I have tried with the same results, so I don't think the amp is defective.
Doug
[mod note ... image deleted as it didn't show any information]
Doug
