headlight dimmer circuit help
unni
Dec 13, 2010
6
Dec 13, 2010
6
I,ve attached the circuit of the headlight dimmer circiut which I am doing for mini project.But I can't understand the current ratinng of the high current relay and How do i connect the 3 outputs to the headlight circuit.Pls help.
davenn
14,260
14,260
the hi current rating of that relay is so that it can handle the "high Current" needed to operate the headlamps without burning out the relay contacts
the top wire ... to hi beam cct ... goes to the hi beam globes (or hi beam filament of a dual beam globe) the other side of the globe goes to the car chassis
the middle wire ... as it says ... goes to the lightswitch on the stearing column
the other side of the switch goes to the battery
the lower wire ... to lo beam cct... goes to the lo beam globes (or lo beam filament of a dual beam globe) the other side of the globe goes to the car chassis
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
Since the coil current of K1 will pass through R3, it'll need to be a high sensitivity type with a high coil resistance, maybe a reed relay. It only needs to switch 0.1A.
K2 will be bigger, having a much lower coil resistance (maybe 150 ohms), and will need to switch at least 10A, preferably 20A (to allow for a 4-lamp setup).
See attached image for actual headlamp wiring.
