Should not have any difference when everythign works properly.
HDMI is digital signal that normally goes through the cable without
any alternation. If the thign get so bad that the bits start
changing (broken cable, loo long cable, strong interference etc..)
then you will definately see that something is wrong.
At normal short few meter logn HDMI cables the data should go smoothly
no matter which HSMI cable you use. When trying to make very long cable
runs then with some equipment combinations some cheaper cables
might nor work but with some other equipment they work without problems.
The more expensive HDMI cable could be marginally better (but there
is no guaratee that it is) in electrical characteristics than some
cheaper cable. The better electrical characteristics might have
some effect in case you are making so long cable run that the
HDMI data transfer will barely work (just in the edge the
recevier will get 0 and 1 bits right from cable). When you
are in "safe operating zone" (few meters long cables are definately this)
then the data will transfer nicely to other end of cable without
any alternation no matter if the cable is normal quality or marginally better.
So cable differences have practically no difference in normal uses.
All audio and video carrried over HDMI is in digital format.
Since it's a digital signal, it will not make ANY difference at all
what kind of properties the cable has as long bits get right from
one end to other end of cable.
http://www.hdtvmagazine.com/articles/2006/08/hdmi_part_8_-_c.phpsays:
"As with many other products, there are better-constructed cables with
better materials and better plugs, but this industry that offers a
cable for $20 while other company sells a similar application cable
for $300, has certainly created a lot of uncertainty among consumers,
and when quality in a cable performance is not easy to detect those
consumers become skeptical."
Some links:
Is there any difference between a cheap (i.e. $10 HDMI cable)
and an expensive (i.e. $150 HDMI cable)?
http://www.theps3faq.com/?q=node/10
The Truth About Monster Cable, Part 2 (Verdict: Cheap Cables Keep Up...Usually)
http://gizmodo.com/gadgets/hdmi-cable-battlemodo/the-truth-about-mons....
The Truth About Monster Cable - Grand Finale (Part III)
http://gizmodo.com/tag/hdmi-cable-battlemodo/
Spend more on Cables?
How do I choose an HDMI Cable?
http://www.tech-faq.com/hdmi-cable.shtml
