Link to datasheet. http://www.farnell.com/datasheets/1683363.pdf
Question, it states that the Vrms for this device is 1Vrms @ 20kHz. I want to use a humidity sensor in my project with a MCU (PIC18f4550) without lugging around a signal generator. If I use a digital pulse at 20KHz 2Vpeak, will that allow the sensor to work optimally?
Thanks.
Edit, I know 20KHz is quite a high frequency for a MCU output. There are other sensors that operate at a more reasonable 1KHz 1Vrms so the principal of the question is the same.
Thanks.
