I'm having trouble interpreting the section on Closing the Feedback
Loop in the datasheet.
Is there anyone out there with experience with this chip?
There's no difference between this device and any other voltage mode
converter - for fast transient response and to avoid the double pole
you need to add extra filtering.
The RHP zero (which would normally be designed such that it provides
phase boost during final gain roll-off) is at too high a frequency in
boost mode (usually) to act as phase boost for this rather critical
frequency region, so a type III filter is used instead to get proper
phase response *and* fast transient (loop frequency) response..
If you can live with slower loop response, then use a type I filter as
explained in the text.
As far as I can see, the text is perfectly straightforward. In
genereal, LTC's datasheets are superior to most for their power
converters.
Cheers
PeteS
