Harris IC ID
Discussion in 'Electronic Repair' started by Samuel M. Goldwasser, Jan 30, 2009.
  1. I have a PCB with a part marked:
    H721A
    F749AMD
    It's an 8 pin SOIC, with power (+5 VDC) at pin 8 and GND at pin 4.
    Could be an op-amp or TTL based on expected function.
    I'm assuming Harris - the "H" is a bit bolder than the rest.
    Only a few years old, not ancient.
    Google seems to have no clue except that the H721A has been asked about
    on a sci* group in the past, apparently without a solution.
    It really shouldn't be anything unusual or custom,
    Some of it's pins are connected to the outside world via 100 ohm series
    resistors. Part of an interlock on a laser.
    Any info appreciated.
    Thanks!
    sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  2. Franc Zabkar
    Franc Zabkar Guest
    FWIW, I found this tiny snippet of info on a part that may be related
    to the H721A:
    http://www.partminer.com/spdetail/H723A
    H723A
    IC,ESD/OVERVOLT PROTECT,S
    H723A
    SOP-8P INTERSIL
    Another clue may be this post:
    http://www.sxlist.com/techref/postbot.asp?by=time&id=piclist\1999\11\24\071335a.txt
    The author writes:
    "I'm trying to find the manufacturer of a IC in the PicStart board,
    it's a SO8 dual SPST switch and it's marked H721A.
    I've found the analog device ADG721, but I'd like to know others
    manufacturers."
    Microchip's PicStart manual states that the "PICSTART Plus development
    programmer features ... special circuit design techniques to enhance
    ESD protection."
    Here is the datasheet for the ADG721/722/723:
    http://www.datasheetarchive.com/pdf-datasheets/Datasheets-4/DSA-70382.pdf
    It states that "the ADG721/ADG722/ADG723 features proprietary ESD
    protection circuitry". The part is described as a "CMOS Low Voltage 4V
    Dual SPST Switch".
    I suspect that the H721A is in fact compatible with the ADG721.
    - Franc Zabkar
