Harris chip
Discussion in 'Electronic Components' started by Andrew Tweddle, Feb 8, 2007.
  1. I am trying to repair a board with an 8 pin DIP
    labelled
    Harris
    A75002-5
    8642
    It could be a transistor pair or an Opamp or even an optical isolated OpAmp
    All help greatfully received
    Andrew
  2. I wish I could... I had a look at Google, but by the time a component's
    existence is reduced to the kind of monkey diarrhoea I saw there, it has as
    much food value as a wet fart. Can you work with the detail around it, and
    find something that does what must be done? Finding an original looks
    impossible, unless someone here can hand you one by return of post after
    easy payment.
    That crap spewed all over Google just means you haven't a chance of getting
    it from ANY of those idiots, they're just trying to catch your eye and
    waste your time.
  3. Didn't Harris take over the RCA line?
    Also, that number is a bit like a GI chip.
  4. Intersil was another one in the GE chain IIRC.
    Peter
  5. Ross Herbert
    Ross Herbert Guest
    Highly likely it's an OEM specific part number. Since you can't get
    any detial on such devices you will have to sketch out the connections
    to it and then try to match the function to common chips. You might
    get lucky...
  6. Franc Zabkar
    Franc Zabkar Guest
