Harmonic Distortion of step-approximation to sine wave
T
The Phantom
Except of course that you naturally generate only a properly dithered
step approximation, in which case there is no harmonic distortion.
The usual definition of harmonic distortion (THD) used in the audio
business is: Total RMS of harmonics alone/Total RMS of wave
There is a website with some good graphics concerning dither and its
effects on harmonics: http://www.cadenzarecording.com/dither.html
Could you explain, perhaps with reference to some of that site's
figures, how dither of a single frequency sine wave can give a result
having no harmonic distortion?
B
Ben Bradley
Very short answer: The signal still has 'distortion', the dither
turns it into random noise, spread out over the whole available
bandwidth instead of being harmonically related to the sine wave.
Here are a couple more good dither links:
http://www.national.com/an/AN/AN-804.pdf
http://digido.com (Click on articles, then dither)
T
The Phantom
I can see that this question is going to hinge on precise
definitions of some technical terms. I think before getting into it,
I would like to list some of those terms and see what others think
they mean.
Harmonic Distortion
Intermodulation Distortion
Distortion (the unqualified word, note)
MSE (Mean Squared Error)
Having defined the terms, then what does it mean to say that a signal
has "harmonic distortion"
It's interesting to note that most of the "pre-digital era" harmonic
distortion analyzers work by nulling out the fundamental and then
measuring what's left.
Another way to do it would be to have a very good comb filter bank and
pass all the harmonics and only the harmonics and measure the result.
The first method measures THD+noise, while the second would presumably
measure only THD.
Suppose we applied the second method to Figure 9 at:
What would we measure?
Would it be harmonic distortion?
