Hello All,
I was hoping to get some advice on an issue with a Harmon Kardon TS7 sub amp. Initially I had done a minor repair job on it for some broken solder joints ... one on the LFE input jack so that fixed that non functioning input. And then the whole amp out put went bad ( worked at first minus the LFE input ) so found some bad solder joints at Q105 and Q103. Fixed it all up and it worked for a little over a week then the two main power transistors blew. So replaced them and powered up ... it worked for all of 5 seconds and they blew again. I checked every other transistor on the board along with all the polarized caps for shorts ... almost all the resistors surrounding the main driver and power transistors. Couldn't find anything wrong with any other components. So I'm left scratching my head as to what caused the power transistors to blow. The only thing I could come up with was this.
When I repaired the bad solder on Q104, I noticed the base connection for Q106 had a long solder bridge between the pads so I got rid of most of that. So during the search for more bad components I noticed when I had Q106 out of circuit for testing, I noticed a break in the pcb trace going to R114. So then I thought that was the reason for the big solder bridge.
So with all that said ... my question to anyone who is familiar with type of amp design is this ... If the base connection (red arrow on pic ) of Q104 was open ... would it have caused an over current situation down the main output channel ? ( blue line in the pic ) The text in the pic describes how each transistor blew out so take that into consideration when/if Q104's base were to go open.
