Harddisk problem............
Discussion in 'Electronic Basics' started by [email protected], Jul 6, 2007.
  1. Guest
    Recenty, i hav bought 200GB SATA HD for my PC.When i started to
    install Win 2000, it shows only 131GB maximum available unformatted
    space to patrition. Then i installed that OS on that then also it
    shows only 131GB of total space. Then where the remaining 120 GB space
    has gone? Can anyone help me?
  2. Jan Nielsen
    Jan Nielsen Guest
    skrev:
    You probaly need an bios upgrade, also install servicepacks for the
    Windows 2000.
    From a 200GB you will get around 180-195 useable GB.
    Anyway you have found the wrong group, you want one with hardware/edb.
    /Jan
  3. Tom Biasi
    Tom Biasi Guest
    You need to move the jumper settings.
  4. 131 + 120 = 200?
  5. craigm
    craigm Guest
    During installation, when it asks, press F6 and insert a floppy with a SATA
    driver that handles 48 bit addressing. The driver comes from the
    motherboard manufacturer, or chipset manufacturer.
  6. Aly
    Aly Guest
    This is a limitation of your BIOS and/or XP. It is widely documented.
    137GB is the magic figure to type into Google.
  7. Andy
    Andy Guest
    The problem is the Windows 2000 hard disk driver only implements 28-
    bit LBA (2^28 blocks * 512 bytes/block = 131,072 megabytes as shown
    during Setup). In order to see the entire disk, Windows 2000 needs
    service pack 3 or 4, plus EnableBigLBA = 1 in the registry.
