Harbor Freight Centech charger putting out around 150V
Discussion in 'Power Electronics' started by sparkboater, Dec 16, 2020.
  1. sparkboater
    sparkboater
    Dec 16, 2020
    Greetings.
    This charger stopped working so I started trying to learn what was up including learning a LITTLE electronics.
    I cant find a schematic for Centech model Item 60653.
    Essentially I put the charger on a weak battery and hooked it up on 2 or 10 amp and am getting (scary) well over 120v at the battery terminals. No hum from transformer
    I can take pics in a few days but am hoping someone here may have a schematic and give me some test points I can check. I cleaned up internal connection points. Don't see any burning or bulging capacitors.
    Any help appreciated.
  2. Martaine2005
    Martaine2005
    3,104
    851
    May 12, 2015
    This might be normal for that particular charger.
    I have an old Black & Decker charger which has mains across the battery terminals.
    I’ll upload a photo if I remember in a couple of days.(at work).
    What does the chargers label have written on it?. Input voltage and output?
    What chemistry are the batteries?.
    Sorry, should have looked at the photo first!. Mine is an old drill charger.
    Martin
  3. dave9
    dave9
    985
    259
    Mar 5, 2017
    While not as simple as some, it is a linear transformer based design rather than switching, so it should not be too hard to sketch out a schematic, at least part of it. If you're getting roughly the right voltage off the transformer secondary windings then I'd guess the rectifier diode (probably mounted to that internal heatsink plate) is probably blown, or a fuse or breaker.
    These aren't terribly expensive, I wonder if it is the right project at this point in your learning curve, considering it is working with mains voltage, and potentially hooked up to an automotive electrical system (battery in vehicle) where high voltage could cause costly damage.
  4. Bluejets
    Bluejets
    4,424
    938
    Oct 5, 2014
    Could have an internal short on the transformer ....best take it to a service centre before you electroplate some bystander.
  5. dave9
    dave9
    985
    259
    Mar 5, 2017
    ^ But on the bright side, once they're electroplated you can use them as Christmas Decorations. :)
    Martaine2005 likes this.
