Hello, newbie here. I assure you all that I tried to google this, and I did a lot of research before asking my question. I have a few illuminated pushbuttons. I'd like them to be always off, except when pushed. Of course, I can figure out just about every other way to wire it except for this way.
Here is a generic image of my button:
The prongs on the left and right are easy enough, they are the ground and + for the LED light inside of the button. On the bottom is the switch ground, and on the top there are the NO and NC prongs for the switch. I am connecting these buttons to an iPac. The iPac supplies 5volts to the button, and I've had it set up so they are always on (but dim) from the iPac. I can use the PC molex cable to get the 14volts to keep the LED on the button always on. I was also able to mess around with the wiring with a 9volt battery to get the button to only light when pressed, but when I replaced the battery wires with the iPac as a power supply it didn't work.
So, is there a way to wire these buttons so that they are off, but when the person presses it down it lights up? Also, if I use the 14 volt power from the PC I do not want it to fry the iPac.
Also, is this stupid of me? Should I just have them always on or on but off when pressed? I am not sure why I thought always off but lit when pushed would look best? I guess because it is the hardest wiring to figure out!
PS - I don't really know how to read wiring diagrams just yet, so please talk to me like a dipstick. EX: ipac ground to button ground, daisy chain connection to led ground. NC to ipac, NO to LED +.
Thanks!!!
Thanks!!!
