K
KTy
It comes with a CD for that has a windows base interface that you use
with the USB/Serial option port at the top left..
I haven't installed that yet, so i can't give you any details there.
As far as recording, It has a 6k point capture with 4 screens of memory
along with a data transmission settings to connect to the PC.
The Data can be set up to be sent to the PC as Bitmaps or Vector.
And as far as I know, there is no option ( or at least i didn't see
it) to do firmware upgrades.
As far as images, I don't remember saying i was going to put any up
on my web sight? Maybe my memory is getting short ?
And the inputs can be left on at all times.
The DMM and scope inputs are all separate. You don't need to unhooked
any leads when switching. You just push the button on the panel to Scope
or DMM. You note how ever, I don't think there is a way to show both the
DMM and Scope at the same time but, the scope does give you voltage
levels etc..
I have another hand held (LCD) that is a simple dual channel scope of
only 5 Mhz, that uses the same leads for both DMM and SCope. I use that
one for a bag around meter and it's costing about $399 last time i
looked. The DMM is not as wide functioned as you would like it how ever,
it does use scope trace line to show the response of the signal when
doing the voltage, RPM's etc..
have you looked on line at the the DOC's?
http://www.owon.com.cn/eng/HDS1022 USER MANUAL.pdf
"I'm never wrong, once i thought i was, but was mistaken"
Real Programmers Do things like this.http://webpages.charter.net/jamie_5- Hide quoted text -
- Show quoted text -
Thank you Jamie for the report !
I do have read the manual
This HDS1022M is really sweet, the only thing that I can imagine that
is missing for "on the field measurement" is more memory for multiple
(more than 4) screen/data storage... Too bad you cannot plug an USB
stick !
