Hand soldering 0201
Discussion in 'Electronic Design' started by Rouqueen, Aug 6, 2007.
  1. Rouqueen
    Rouqueen Guest
    Hi all
    In a near future, we will design board with 0201 components. My main
    concern is hand soldering as we dont want to subcontract for our
    prototype assembly.
    I have just finished a 0402 assembly (by hand) and even with the
    equipment we have (very small solder tips), it was not a walk in a
    park but it was ok. Our board is pretty dense and sometimes solder
    tips touch another component while soldering another :)
    What do you use for equipment (soldering iron, solder paste or
    wire,....)?
    thank you
    Caroline
  2. Eeyore
    Eeyore Guest
    Do make sure you don't sneeze when placing them !
    Graham
  3. Rouqueen
    Rouqueen Guest
    Indeed :)
  4. You might look into getting a Zephertronics unit:
    http://www.zeph.com/
    Also, the Metcal hoof tips work fairly well for small surface mount
    parts. Instead of directly soldering each pin, you use the tip to
    move a small volume of molten solder around that wicks to the pads.
  5. DJ Delorie
    DJ Delorie Guest
    Been there :)
    http://www.delorie.com/pcb/smd-challenge/
    http://www.delorie.com/pcb/first.html
    The first couple of times around, I used a metcal iron with a 20 mil
    tip, but the wire solder kept balling up instead of wetting the parts.
    Now, what I do is use paste.
    Two options for putting the paste down:
    1. Use a stencil. You can make your own (brass), or have one made
    (mylar, stainless)
    2. Use a syringe applicator and dab it down by hand.
    Two options for reflowing the paste:
    1. Use your iron. A fine tip anywhere near the paste will reflow the
    paste, or you can use a hot air pencil or talon.
    2. Use a hotplate. http://www.delorie.com/pcb/hotplate/ and see the
    tutorials at sparkfun.com.
    With the iron, the tricky bit is holding the part in place while you
    heat it. Either a sharpened toothpick or fine placement tweezers will
    do, but don't trust the iron to not pick the part up once the solder
    melts.
