Hammond Gaining Access To Key Contacts
Discussion in 'Troubleshooting and Repair' started by Sticky Fingers10, Aug 31, 2018.
  1. Sticky Fingers10
    Sticky Fingers10
    Aug 31, 2018
    Question is how to gain access to the contacts beneath the key bed to clean contacts. Spilled drink on to key bed. 3 keys not functioning. Inverted Xk3c to drain and removed right end block to possibly see but to cluttered to gain access. Also how to remove keys ?
  2. dave9
    dave9
    955
    248
    Mar 5, 2017
    I would start by taking the screws out and popping the case open. The keys are probably hinged on the chassis or a frame and the circuit board with the switches may separate away from the mechanical assembly.
