Hall sensor
Discussion in 'Sensors and Actuators' started by evans101, Feb 24, 2018.
  1. evans101
    evans101
    Feb 24, 2018
    Hi
    Can anyone help me with this?
    If a Hall effect magnetic sensor is designed to operate at 30°C, how much temperature variation would be tolerable for a Hall voltage accuracy of ±10% -I have I graph of hall voltage vs the absolute temperature but I am not sure how to go about this
  2. (*steve*)
    25,305
    2,738
    Well, find compare the graphed output voltage at 30 deg too the temperature you expect to operate it at and see if it varies by more than 10%
  3. evans101
    evans101
    Feb 24, 2018
    Hi Steve
    Thanks for the reply. I'm kinda confused because i dont know the temperature its supposed to operate at .
    I have attached the graph
  4. Bluejets
    Bluejets
    3,780
    783
    Oct 5, 2014
    Tip.....it is in reference to it's environment. I'm guessing it would be of little concern to you.
  5. timff
    timff
    19
    Apr 13, 2018
    The graph showing 300 Kelvin is equal to 80 degrees F (27C) it goes to 440K (332F / 167C)
    Since this is mostly above normal environmental conditions, one might assume it is intended to show how the device should be derated under extreme conditions.
    Since the curve seems to be flattening out below 320K (116F / 47C), one might assume that the device performance is more linear at lower temperatures.
    Rayregula likes this.
