hall sensor - quiscent voltage
Discussion in 'Sensors and Actuators' started by vamsee, Feb 27, 2013.
  1. vamsee
    vamsee
    36
    Jan 10, 2013
  2. davenn
    davenn Moderator
    13,866
    1,958
    what voltage are you measuring across the resistor load ?
    and do you get any change in voltage when a magnet is moved to and away from the device ?
  3. vamsee
    vamsee
    36
    Jan 10, 2013
    Hi, thanq for the reply..
    I am measuring 0.71V without magnet... and 0.11V when magnet placed near to it...
  4. Harald Kapp
    11,660
    2,696
    You need to connect all 3 pins. Ground is missing from your schematic and probably from your circuit, too.
  5. vamsee
    vamsee
    36
    Jan 10, 2013
    i have connected them to ground.. -ve's of battery, voltage regulator, hall sensor, capacitor and resistor..
  6. Harald Kapp
    11,660
    2,696
    Your schematic doesn't show this.
    Are your sure that you have the pins right (especially input and output)?
  7. vamsee
    vamsee
    36
    Jan 10, 2013
    I checked these initially and then came for ur help.. inputs, outputs and gnd all carefully checked and connected.. But still i wonder y i am not getting the result as expected..
    its not a tough circuit though, since its simple one and not getting the result, i am feeling really bad...
  8. vamsee
    vamsee
    36
    Jan 10, 2013
    let me explain by words..
    positive of battery is connected to the input of voltage regulator(VR) and output of VR is connected to the 5V power line in the breadboard.. the positive of capacitor is connected in the 5V line. The input of hall sensor is connected to the positive of capacitor. the ouput of hall sensor is connected to the resistor. All -ve and gnds are connected to the ground line in the breadboard... Finally the output is measured across the load resistor..
  9. vamsee
    vamsee
    36
    Jan 10, 2013
    Hi!! Should i use capacitor between positive and gnd of voltage regulator?
  10. Harald Kapp
    11,660
    2,696
    Yes, always. Both on input and output. Se the application notes for the chip you use.
    Without capacitor most regulators are not stable.
  11. vamsee
    vamsee
    36
    Jan 10, 2013
  12. Harald Kapp
    11,660
    2,696
    Sorry, I wasn'r entirely clear: I meant the application note for the voltage regulator you use.
  13. vamsee
    vamsee
    36
    Jan 10, 2013
    the whole circuit is similar to me... but i didnt use the capacitors as used there...
    is my hall sensor is correct? i mean, am i using correct hall sensor?
  14. Harald Kapp
    11,660
    2,696
    Correct for what or in which way?
    Did you try the capacitors?
    Have you measured the output of the voltage regulator?
  15. vamsee
    vamsee
    36
    Jan 10, 2013
    i just ordered the capacitors ;) have to wait till tomo..
    ya i measured the output of voltage regulator and it showed 5V..
  16. CDRIVE
    4,960
    652
    May 8, 2012
    Initially I was betting that a 47R was mistaken for a 4.7K but the Data Sheet specs Zo = 2R min - 5R max. So even a 47R wouldn't load it this much. What does the output measure with no load?
    Second thought... The A1301 is Kaput.
    Chris
  17. vamsee
    vamsee
    36
    Jan 10, 2013
    HI!!
    the hall sensor output measuring 0.71V without magnetic field...
  18. CDRIVE
    4,960
    652
    May 8, 2012
    OK, sorry about that. It should be close to zero then. Once again... bad sensor, wired wrong? Not much options left.
    Chris
  19. vamsee
    vamsee
    36
    Jan 10, 2013
    http://www.allegromicro.com/Product...ICs/Linear-Position-Sensor-ICs/A1321-2-3.aspx
    in the above link, they have mentioned thatA1321, 22, and 23 have been altered.. Unfortunately i am using A1322. Will this be the reason, for not getting the output?
    i have ordered the alternative as well...
  20. Harald Kapp
    11,660
    2,696
    According to the datasheet the A1321-1232 differ in noise and sensitivity, but all should have Vout=50%Vcc at zero mag. field. Something else is wrong.
    Can you measure the Vcc and Vout with an oscilloscope to verify that these voltages are straight DC and none of the components is oscillating?
