Hall Effects Switches
Discussion in 'General Electronics Discussion' started by SmokedCircuit64, May 12, 2011.
  1. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    So... Here goes my first stab at things..
    I need a triggering/switch type device for a project.. The first thing that came to my mind was a Hall Effect switch because I have moving parts and they can’t touch but need to interact. I will be using a 12 VDC supply to trigger an electromagnet. I don’t want constant current supplied; rather I need a timed pulse of current to activate, then turn off until it is needed again.
    My thought path.. 12 VDC in, current remains at the ready till switch allows current to flow and activate electromagnet then turns off current. Kinda like a regular light switch!
    My issue is that I have NO IDEA what type of hall effect switch I need to look for.. I have seen switches that can take 4 to 24 VDC of input, but the output always seems to be way less than what I need or doesn’t equal the input.
    Thanks for the assistance.
    Kevin
  2. (*steve*)
    25,499
    2,839
    In general the hall effect switch would control a device like a MOSFET which would switch a larger current.
  3. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    What would a circuit look like that has the MOSFET and hall effects working together? Is there a name for that type of switching circuit?
  4. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    Hi SmokedCircuit
    How fast will the switching need to happen, and at what frequency, please?
    Ohh, your new post just came in so I'll edit:
    You question: "What would a circuit look like that has the MOSFET and hall effects working together?"
    Generally speaking, the current from the Hall Effect device is made to control a transistor or similar current-amplifying device. Sometimes, that general statement is wrong, it is the voltage which does the controlling. Too confusing.
    Please pick a Hall-effect device for your example, and I for one will try and design and post a circuit for it. Do please remember to say how often the device will get triggered (how fast does your shaft or whatever rotate).
    See ya then
    :-D
    (PS I've smoked a few circuits myself but perhaps I'd prefer to smoke fish)
  5. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    Poor Mystic,
    I am a total new-bee with this stuff.. Mechanical stuff I can make dance, but anything electronics wise I just make smoke.. Hence the user name.. LOL:rolleyes:
    I'll explain my ideas.. So i have a flywheel roughly 6" dia.. I thought I would just drill and insert a small magnet into the flywheel at a position just after TDC to trip the hall effect switch which would then fire the coil.. "steve" said I need a MOSFET to do the switching and the hall effect to trigger the MOSFET.
    So you asking me the speed I need this to happen is something I really don't understand.. If I had to take a stab at it, I would guess a few mili-seconds.
    Will any hall effect work? and where can I find then to pick you one out..
    Sorry if this isn't as simple as it should be.. But I really thank you for your assistance..
    Kevin
  6. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    So, SmokedCircuit! :-D
    sounds like you're building an electronic ignition. As far as I know it is very easy to design an electronic ignition system that is unreliable and a plain hassle.
    Have you considered using the electronic ignition sets already on the market?
  7. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
  8. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    How about this:
    Here is the info on it:
    SENSITIVE HALL-EFFECT SWITCHES FOR HIGH-TEMPERATURE OPERATION A 3144 E 44
    A3144E
    this item will not be supplied shipping tracking number if you want tracking number please pay extra 1.5 us dollar!
    please send us an email to confirm for needing tracking number as soon as you order it . and please set confirmed
    address in paypal other wise we will not send out before we get confirmed address
    of your paypal!
    These Hall-effect switches are monolithic integrated circuits with
    tighter magnetic specifications, designed to operate continuously over
    extended temperatures to +150°C, and are more stable with both
    temperature and supply voltage changes. The unipolar switching
    characteristic makes these devices ideal for use with a simple bar or rod
    magnet. The four basic devices (3141, 3142, 3143, and 3144) are
    identical except for magnetic switch points.
    Each device includes a voltage regulator for operation with supply
    voltages of 4.5 to 24 volts, reverse battery protection diode, quadratic
    Hall-voltage generator, temperature compensation circuitry, smallsignal
    amplifier, Schmitt trigger, and an open-collector output to sink
    up to 25 mA. With suitable output pull up, they can be used with
    bipolar or CMOS logic circuits. The A3141– and A3142– are improved
    replacements for the UGN/UGS3140–; the A3144– is the
    improved replacement for the UGN/UGS3120–.
    The first character of the part number suffix determines the device
    operating temperature range. Suffix ‘E–’ is for the automotive and
    industrial temperature range of -40°C to +85°C. Suffix ‘L–’ is for the
    automotive and military temperature range of -40°C to +150°C. Three
    package styles provide a magnetically optimized package for most
    applications. Suffix ‘–LT’ is a miniature SOT89/TO-243AA transistor
    package for surface-mount applications; suffix ‘–U’ is a three-lead
    plastic mini-SIP, while suffix ‘–UA’ is a three-lead ultra-mini-SIP.
    FEATURES and BENEFITS
    Superior Temp. Stability for Automotive or Industrial Applications
    4.5 V to 24 V Operation … Needs Only An Unregulated Supply
    Open-Collector 25 mA Output … Compatible with Digital Logic
    Reverse Battery Protection
    Activate with Small, Commercially Available Permanent Magnets
    Solid-State Reliability
    Small Size
    Resistant to Physical Stress
    ABSOLUTE MAXIMUM RATINGS
    at TA = +25°C
    Supply Voltage, VCC ............................ 28 V
    Reverse Battery Voltage, VRCC ........... -35 V
    Magnetic Flux Density, B .......... Unlimited
    Output OFF Voltage, VOUT .................. 28 V
    Reverse Output Voltage, VOUT ........... -0.5 V
    Continuous Output Current, IOUT ...... 25 mA
    Operating Temperature Range, TA
    Suffix ‘E–’ .................. -40°C to +85°C
    Suffix ‘L–’ ................ -40°C to +150°C
    Storage Temperature Range,
    TS .............................. -65°C to +170°C
    ELECTRICAL CHARACTERISTICS at VCC = 8 V over operating temperature range.
    Limits
    Characteristic; Symbol ;Test Conditions ;Min. Typ. Max. Units
    Supply Voltage ;VCC; Operating; 4.5 -- 24 V
    Output Saturation Voltage ;VOUT(SAT); IOUT = 20 mA, B > BOP ;-- 175 400 mV
    Output Leakage Current ;IOFF; VOUT = 24 V, B < BRP; --<1.0 10 UA
    Supply Current ;ICC; B < BRP (Output OF—F);- 4.4 9.0 mA
    Output Rise Time ;tr; RL = 820 Ω, CL = 20 pF ;— 0.04 2.0 Us
    Output Fall Time ;tf; RL = 820 Ω, CL = 20 pF ;— 0.18 2.0 Us
    MAGNETIC CHARACTERISTICS in gauss over operating supply voltage range.
    Characteristic Min. Typ. Max.
    BOP at TA = 25°C Min.70 Typ.-- Max.350
    over operating temp. range Min.35 Typ.-- Max.450
    BRP at TA = 25°C 50 — 330
    over operating temp. range 25 — 430
    Bhys at TA = 25°C 20 55 —
    over operating temp. range 20 55 —
    I have no idea what any of that means!
      File size:
      5 KB
      127
  9. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    es your correct.. Thanks.. I'll do a search
  10. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    wow
    ok so don't examine me too closely either... "quadratic Hall-voltage generator" tells me I have reading to do.
    But I see nothing here to be skeptical about. Looks a lot easier than homemade that's for sure.
    Is this equipment very expensive?
  11. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    You told me to go find one and let you know, so I went to eBay (as usual when I'm looking for something) I need.
    Here is the link:
    http://cgi.ebay.com/10-HALL-EFFECT-...&otn=3&po=LVI&ps=63&clkid=9111164710449887466
    it is like $10 for 10 of them.. So I take it I found something good?
    Oh Yeah I found a a site where a guy sells a kit for $22 - $26 depending on the bells and whistles you want..
    Here is the link:
    http://www.jerry-howell.com/IgnitionModules.html
    I just need to ask him if he can rework it for 12 volts..
  12. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    How excellent to see your project moving ahead.
  13. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    Which do you think would be the best way to go?
    Using the hall effect switches I posted the info for or to go with the circuit kit Jerry Howell has?
  14. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    well I got a 404 when I followed the first link so Jerry wins by default I guess
  15. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    So the ebay link didn't work? I was trying to save you the time in searching for it by using the link..
    If you just got to ebay abd put the item number in the search box you should be able to get there..
    Item number: 140509114859
    Hope that works for you!
  16. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    Hi SC
    OK, those look like good detectors... you want a timed pulse?
    You need to know how to build a single-pulse generator, also called a monostable vibrator.
    You need to trigger the monostable with the Hall-Effect device, and the monostable o/p controls a power transistor.
    There are 3 stages to the circuit I imagine you want
    1) Hall-Effect device
    2) monostable
    3) power output
    How will you design your monostable?
    PS But I think you're better off with Jerry
  17. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    I think your right.. I'll go with the JEH Circuit Kit. At this point in my learning curve, I need to study how it functions before I can attempt some other sort of design. The kit will have all the parts needed so I will always have a reference once i'm ready to interduce mods to it.
    Thanks for the help..
    now if I could get some concrete info and or feed back on building an elecrtomagnet based off my idea I would be off to a running start.
    Thanks again
    SC
  18. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    Here I am full of questions again.. LOL
    I was just thinking..
    So the JEH Circuit kit is for a 6 volt system.. What would have to be done to it for it to be used with 12 volts?
  19. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    Ask the guys at JEH, whose opinion comes with a guarantee!
  20. SmokedCircuit64
    SmokedCircuit64
    13
    May 12, 2011
    Well.... They haven't returned my email yet! I may be back at square one again. So, planning on not ever hearing back from JEH.
    I have a few questions..
    1) What MOSFET type would I need?
    2) What Hall Effects Switch type do I need?
    3) What other items are required to build the circuit?
    The circuit needs to run on 12 volts. The circuit seems simple enough to lay out. I could probably just burn it up once if I'm lucky.. LOL
