Hall effect sensor trigger LED
Discussion in 'Sensors and Actuators' started by bramar1, Apr 2, 2015.
  1. bramar1
    bramar1
    Apr 2, 2015
    I am currently working on a project and I would like to see if I am on the right track.
    Using a 9V battery supply I have a hall effect sensor (2SS52M, Hall Effect Sensor, Omnipolar, 2.5mT, 3.8 → 30 V dc, 3-Pin TO-92) which will output to a Schmitt trigger (TC4S584F(F)).
    I want to know, is my output voltage from the schmitt still +9V?
    with these values is my high V point approx. 2.0V and low V point approx. .6V?
    Basically I want the hall effect sensor to light an LED when magnetic flux leakage has been detected. Any help greatly appreciated! :)
  2. hevans1944
    hevans1944 Hop - AC8NS
    4,596
    2,149
    Jun 21, 2012
    Your circuit diagram does not agree with the datasheets for either the Hall sensor or the Schmitt trigger. See attached datasheets.
    The Hall device is a current-sinking output, which means you supply a voltage supply to the output through a current-limiting resistor. The Schmitt trigger has no provision for positive feedback and has no negative input terminal.
    Please revise your schematic and try again.
