You could try it but the module does need a heat sink. & keep an eye on the heat generated. Another distributor you should keep an eye out for is whats used on Ford Falcon models EA to EL. It has the same Hall sensor & the Thick Film IGN unit has built in over current cut off if the engine stops & the coil is still drawing current. Pict is the TFI unit on Fords.
Categories
Platforms
Content
