half duplex
Discussion in 'Electronic Basics' started by [email protected], Oct 30, 2006.
  1. Guest
    I was just wondering if half duplex Ethernet uses all four pins on the
    RJ45 plug (like full duplex).
    Thanks.
  2. Baron
    Baron Guest
    No ! Only two.
  3. John
    John Guest
    It uses the standard pin-out. In this case, half-duplex refers to the
    limitations of the netwrok card(s) being used.
    John
  4. Guest
    Which two?
  5. Baron
    Baron Guest
    Of the top of my head ! Can't remember... Google RJ45 Wireing.
  6. Lionel
    Lionel Guest
    Well, RJ45s have 8 pins, not 4. And yes, half-duplex uses the same
    pins as ful duplex. The difference between half & full duplex is
    whether the port can receive & transmit at the same time, (Full can,
    half can't), which has nothing to do with the number of pins or pairs
    required.
    If you're asking because you want to save on wiring or somesuch, what
    you really want to know is how many pins/pairs are required for
    differnet Ethernet standards. If you describe your requirements in
    more detail, I'm sure someone here will be able to answer your
    question more usefully. :)
  7. Lionel
    Lionel Guest
    Incorrect. 10bT & 100bT both require two pairs, 1000bT requires all 4
    pairs.
  8. feebo
    feebo Guest
    unless this is a deliberate deception (homework troll?) the answer you
    give is nonsense.
  9. feebo
    feebo Guest
    RJ45 uses 8 connectors (4 pairs)... RJ11 uses 4 connectors.
    you need them all regardless of the duplex setting - this article
    gives a nice pic of how to connect:
    http://www.lettronics.com/default.asp?page=article_rj45
    Duplex in ethernet only refers to the network component (including -
    at this level - the network card in your PC) being able to send and
    recieve simultaneously (full duplex) or only to do one at a time (half
    duplex)
  10. Baron
    Baron Guest
    Not really ! An RJ45 connector has 8 pins, or if you prefer 4 pairs of
    wires. Two independent full duplex Ethernet channels can be run down a
    single length of cat 5 cable.
    Since the OP asked if half duplex uses all four pins then the answer I
    gave was correct !
  11. feebo
    feebo Guest
    they call this "using the letter of the law to defeat the spirit of
    the law"
  12. feebo
    feebo Guest
    just read the OP and your reply and am now more convinced than ever
    you are a bullshitter!
    the op asked if half duplex used 4 pins (like FDX) it does. so the
    answer is yes. you replied No, only two - nothing was said about pairs
    you implied only two pins (wires) are used for HDX.
    You are Billy Bullshit and I claim my $10
