M
Mike V.
On many half bridge driver ICs (e.g. international rectifier, ST,
Intersil), you would use two of them, along with four MOSFETs to make
an H-bridge configuration. They also give the layout guideline that
says:
"The motor driver IC's ground and the motor ground should all meet at
ONE point." (Sort of like star grounding?)
That rule is easy to abide by, especially if it is a 2-layer board.
What about if my board is a four-layer board? Can I simply flood the
whole area with a ground plane, and just drop every ground pin into
the ground plane? Thus the driver IC would have 12vdc-15vdc as its
Vcc, the motor can have 100Vdc, and they all share the same ground
plane. Or am I going to have problems by simplifying the layout with a
ground plane instead of following the "all meet at one point"
guideline?
Mike
says:
guideline?
Mike
