H bridge loading problems
Discussion in 'General Electronics Discussion' started by thekaiser11234, Jul 8, 2012.
  1. thekaiser11234
    thekaiser11234
    Jul 8, 2012
    hello guys im new here
    i dont really know if its the right place for the post
    as i have been working on h bridge for awhile its my 1st design as you see below
    using it to control 14amp 24 volt (250 watt) motor
    controlling using Arduino (500hz frequency )
    (1-0) move in 1 direction
    (0-1) other direction
    (1-1) Break
    the upper side is P channel IRF9540 or 9540N i used both
    http://www.irf.com/product-info/data...a/irf9540n.pdf
    the lower side is N channel IRF540 or IRF540N also
    http://www.irf.com/product-info/data...ta/irf540n.pdf
    for level shifting ( 5 to 12v)
    im using BC547 NPN
    http://www.futurlec.com/Datasheet/Transistor/BC547.pdf
    to keep the voltage (VGS and VSG ) for P and N transistors
    im using 12 v zener
    here they name it only by voltage and wattages
    im currently using 1 watt zeners
    the max available is 5 watt
    R zener is 1k in case its not obvious enough !
    the driver works fine without loading
    but if i add them my sort of cart project
    15k load ( current consumed 10-12 amps )
    the motors dont seem to move the transistor HEAT AND HEAT then they blow !
    can you guide me whats the problem
    sorry for the long post ,just hoping for help asap !
    ah the schematic :)
    http://desmond.imageshack.us/Himg690/scaled.php?server=690&filename=hbridge.png&res=landing
    i'd like to add
    i tried to decrease the load and see whats gonna happen
    the robot moved
    but too slow the first voltage was about 3 v or something and keeps increasing as the motor moving within a noticable speed
    the current drawn is around 5 ampere
    any thoughts ? :S
