GUI (Graphical User Interface ) problem
Discussion in 'Microcontrollers, Programming and IoT' started by nkey292, Mar 26, 2014.
  1. nkey292
    nkey292
    11
    Mar 26, 2014
    hello dear friends,
    i am working on a video transmission project, and i need to make a Graphical User Interface, when the device is connected the TV, an interface that will give the user the ability to have command and choose, ...
    i don't know how to make it, which chip-set and programming language to use to make a GUI
    thank you guys
  2. Dylan Wisdom
    Dylan Wisdom
    26
    Apr 10, 2014
    Are you fluent in any programming languages?
  3. BobK
    7,682
    1,686
    If you want a graphical UI on a TV, a Raspberry Pi is probably your best bet.
  4. Anish
    Anish
    46
    Feb 5, 2011
    Whatever chip you use, the easiest gui programming lanugage might be processing (similar to arduino in syntax - but processing came first).
    You can receive/send values through serial port and use processing as the GUI
    Processing is easy to learn, and opensource also you can find many examples at processing website.
  5. (*steve*)
    25,404
    2,777
    I think you'll find that C++ beat it by a couple of (actually 22) years.
    "arduino language" is C++
