Grow box led light power?
Discussion in 'LEDs and Optoelectronics' started by Xenosis, May 1, 2017.
  1. Xenosis
    Xenosis
    May 1, 2017
    Hello
    I'm planning on building a grow/display box for a bonsai tree, but I need some advice on how to power it all..
    I already got this led strip, I would like to use:
    3014 SMD 600 leds 5M
    Lumens Flux: 1200-1440
    Color Tempature: Cool White 6000k-6500k
    Power: 60W/5M
    Supplied with: DC 12V 6A adaptor
    But I also need to find some leds for the top/ceiling on the box. So I found this light, that I think would fit nicely in the box:
    18W 5050SMD LED Day White Magnetic Panel Ceiling Lamp 220-240V AC
    This is all the light I need (I hope)
    The problem is I only want one power cable connected to the box and power the Led strip and the Ceiling Lamp , also the option to expand as I describe below:
    In my search online for inspiration I've seen people use RPI and arduino to make stuff like soil humidity sensors etc.. I think it could be fun playing around with at a later time.. So I would love to have the ability to expand the setup with a RPI and arduino still powered from the main power cable..
    I guess the DC 12V 6A adaptor supplied with the led strip wont work..
    So what are my power options?
  2. Audioguru
    Audioguru
    3,260
    701
    Sep 24, 2016
    The ceiling lamp is powered from 220-240VAC but isn't the DC 12V 6A adaptor also powered from 220-240VAC? Then connect both of them to the same AC power cable.
  3. Xenosis
    Xenosis
    May 1, 2017
    Yes that sounds like a valid option, but how do I expand the setup with a RPI later?
    I've seen people use PC power supply to power led strips, rpi etc.. So I'm looking into this option..
    I have just removed the PSU from a Lenovo Thinkcenter M55
    Will this be enough to power my led strip, led celing PCB and later some raspberry and arduino fun?
