W
weco
This came up at work recently and I'm not convinced it was dealt with
properly so I thought I'd pose the question to the group and see what you
guys thought....
We have a solvent reclamation machine that was recently installed. It is
technically not in an explosive atmosphere but there are explosive drums of
solvent connected to it...
The machine and the drums required grounding, and the commisioning
instructions were confusing. Additionally the Field engineer did not seem to
know what to do - he was more of a software guy...
We bonded the machine direct to a main ground with a #8 wire and the drums
have ground cables clamped to the fill pipes and then directly to ground as
well.
While this will serve to keep the system at zero volts it is a very low
impedance path to ground, and should a charged body approach any part of the
machine especially around the drums, there would probably be an arc
discharge.
Seems to me this is not what was intended by the grounding system
For electronics work (my background) we use mats with a relatively high
impedance to slowly bleed charge potentials down to prevent the arc....
I've looked through the NEC but have not found any rules specifically
relating to this problem....
I know from my compliance testing background that we used resitors in ground
paths to minimise the arc discharge in areas other than the equipment under
test, and there are standards that describe what and where they should
be....
I dont want to allow ignorance to create a dangerous situation here but none
of the plant electricians knew anything...
Any thoughts???
henry
guys thought....
well.
discharge.
be....
Any thoughts???
henry
