grounding dc circuits
Discussion in 'General Electronics Discussion' started by Madsalts, Feb 22, 2015.
  1. Madsalts
    Madsalts
    73
    Sep 25, 2014
    I'm making two devices, both of which will run off of "wall warts" providing 12V. I will be running motors, and have fuses that are rated to about 40% stall current. I'm wondering if I need to (should) ground the DC supply in relation to the device housing. In the first case, I will be trying to insulate the power path from the case, as the power jack is a steel alloy and the case is aluminum (re: corrosion issues). In the second case, the case is steel.
    So, what would you recommend? Thanks.
  2. davenn
    davenn Moderator
    13,901
    1,971
    I don't see any reason why you should need to ground the negative side to the case
  3. Madsalts
    Madsalts
    73
    Sep 25, 2014
    ok, thanks
