Grounding a blower motor
Discussion in 'General Electronics Discussion' started by edennis, Jul 13, 2018.
  1. edennis
    edennis
    21
    Jun 12, 2018
    Is it correct to ground a blower with a wire going from the metal blower case to the ground wire in the AC plug?
  2. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    Normally if a mains fed device is not double insulated, then it should be earth grounded to the device or motor frame.
    M.
  3. K9WG
    K9WG
    25
    6
    Mar 8, 2018
    Yes. Ground the frame to the ground blade of the plug.
  4. edennis
    edennis
    21
    Jun 12, 2018
    Thank you.
  5. Bluejets
    Bluejets
    4,990
    1,048
    Oct 5, 2014
    Note as Minder says, i.e. NOT double insulated.
  6. edennis
    edennis
    21
    Jun 12, 2018
    How do I know if the blower is double insulated? And what should I do if it is- not ground it?
    Thanks for answering my super basic questions.
  7. Bluejets
    Bluejets
    4,990
    1,048
    Oct 5, 2014
    On the motor label there should be identification which says as such .....
    OR... there will be a marking of two squares, one inside the other.
    If it is double insulated, do not earth.
    https://en.wikipedia.org/wiki/Appliance_classes
    If in doubt, ask your local electrician.
    davenn likes this.
  8. radar.bob
    radar.bob
    5
    Feb 18, 2018
    Not sure what kind of blower you are referring to. If in doubt, connect the earth lead, if it has one.
    Any electrical device with a metal casing MUST be earthed.
    I strongly suggest you call an electrician, and follow his advice.
  9. Bluejets
    Bluejets
    4,990
    1,048
    Oct 5, 2014
    An electrician has already given the Op advice.
  10. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    Make that two.;)
    M.
    Bluejets likes this.
