Ground and Ground plane on 2 layer board
L
Liuc
Hi everybody,
I am doing a design of 2 different boards and I am struggling about the
use (or abuse?) of the Ground Plane.
Both the boards have a SMPS (LM2575) that generate 3.3VDC from an input
of 12/24 V AC/DC. The CPU on the 2 boards are 8 bit microcontrollers
(PIC18) , one running at 20 Mhz and the other at 4Mhz. No signal on
both the boards is running faster than these frequencies.
Both the boards have a SPI EEPROM, an RTC and a RS485 transceiver. The
20Mhz board has 4 relay outputs and 4 optoisolated inputs, whilst the 4
Mhz board has only 1 relay output.
The boards are both routed 95% on the top layer, I use the bottom only
for VCC and GND and for few lines that I wasn't able tofit on the top
layer.
My question is: how to use the ground plane? I've read plenty of
threads about it, but I didn't fully understand which is the best way
to do. My doubts are mainly about:
1) GND of the SMPS: the SMPS is located in a definite area of the PCB,
so I made a GND plane "all for it", and connected to the rest of GND
plane in a single point witha thick trace. Is it correct or is it
better to make a big plane for all the pcb?
2) GND of the relays: I made a GND line only for relays , and connected
it with the GND plane only in one point. Correct or not? (in the relay
area there is no GND plane at all, top and bottom layers)
3) grounding of the RTC (DS1302): should I take particular precautions
about the GND plane surrounding the RTC and its crystal? (also about
the 20Mhz crystal)
4) FUll or grid gnd plane? For my pcb manifacturer it's the same, so I
have to choose...
more generally speaking, not having RF stages on my boards, once
finished the routing I filled in almost all the unused PCB area with a
GND plane, both top and bottom layer. Of course I was checking that I
had as few interruptions as possible, specially on the bottom layer,
even if I need to have some (for Vcc and for the 5% of routing descrbed
above)
But is this a correct approach or I am making everything wrong? Should
I use only the bottom layer for the GND plane? or is ok to fill
everything fillable? :)
I know that using a 4 layer board would make everything easier, but I
have to keep my design in a 2 layer... no way to change this!
I think that's all, sorry for the lenght of this thread but I wanted to
put out all my doubts, so that maybe it can be useful also for other
people.
Thanks since now to everybody who can help, all the best,
Liuc
M
Mr. Wizard
Using a single point ground that you are using should be fine. Make
sure that you try and locate this star ground as close to the exit
point on the PCB. If you check out National's website for app notes
N
Noway2
Liuc said:
Hi everybody,
layer.
the 20Mhz crystal)
have to choose...
above)
people.
Liuc
Speaking generally and not getting into the specifics of your design:
The purpose of the power (ground) system is to provide a constant
voltage supply to your logic circuit. This supply must present the
constant voltage in the presence of varying and surging currents caused
by the electronic switching. In order to maintain this regulation, the
power (ground) system must have a very low impedance across a fairly
significant bandwidth. The exact bandwidth that you need to be
concerned about depends not so much on the clock rate of your circuit
(the 20Mhz and 4MHz that you mention) but the rise and fall times of
the digital signals. Providing the constant voltage, low impedance
supply is often accomplished through proper use of decoupling
capacitors. You didn't mention them in your design, but if this
concept is new to you then you should investigate it.
Many, especially novice, designers also forget about the return
currents. When they look at a circuit schematic they see a driver
connecting to a receiver and the current path between them is obvious.
What is not as obvious is that there is also a return current, through
the 'ground' path between the devices. The ground path needs to be as
low of an impedance as the power path. The only structure that will
provide a sufficiently low impedance for the ground is a wide flat
structure, or a plane. The reason being that at the frequencies of
interest, which as I pointed our earlier are far greater than your
clock rate, the impedance of the ground becomes dominated by the
inductance and to get a low inductance (impedance) you need a wide flat
structure. A ground plane that is full of holes is still infinately
better than a serpentine trace.
A copper pour will work for a ground plane. On your board which is two
layer, it probably matters little wether the plane is on the top or
bottom side of the board. If you are planning on wave soldering the
board, you may want to consider putting the ground plane on the 'top'
as it is possible for the board to warp when it is exposed to the wave
solder, though this is a more minor consideration.
Regarding the point about a single ground connectiont that was
mentioned, you want to keep in mind how current will flow. The idea is
to avoid multiple ground paths into or out of a circuit or region of
the board as these cause ground loops which can cause ground voltage
differences in the board and open the window for EMI.
L
Liuc
Hi Noway2,
first of all thaks to you and to Mr. Wizard for your answers.
About what you wrote, you are right: I forgot to write about dec
capacitors. I am using a 100nF capacitor (ceramic multilayer) on each
Vcc pin of the ICs used in the 2 boards.
I still have a question: how can I estimate correctly the bandwith "to
be concerned about" about my digital signals? I mean, the digital
signals involved in my boards are:
lines for relay switching -> very slow switching
line for inputs -> also there I think the signal is enough slow
serial communications:
rs485, working at 9600bps
I2C and 1Wire bus, same speed
so which is the correcnt approach to estimate bandwith for the
impedance of the ground (power) system?
thanks again
Liuc
Noway2 ha scritto:
P
Paul Mathews
Liuc said:
Hi everybody,
layer.
the 20Mhz crystal)
have to choose...
above)
people.
Liuc
The most useful concept to understand is 'loop area', part of which is
the idea of 'return currents', as discussed in another msg this thread.
By minimizing loop area, you will be minimizing inductances. Large
copper pours, including ground planes, provide one way of minimizing
loop areas. However, on a 2-layer board, it can be difficult to avoid
cutting up the ground pour, so that there are numerous 'moats' and
'slots'. Study this subject until you understand why such features
should be avoided where possible and how you can route traces on the
other layer so that return currents are not forced to go around the
moats and slots. Keywords for your search are: circuit board, layout,
inductance, loop area, moat, slot. There are also many excellent
articles and books by authors including: Mark Montrose, Howard Johnson,
Sanjaya Maniktala.
Paul Mathews
John Larkin
Hi everybody,
layer.
the 20Mhz crystal)
have to choose...
above)
people.
Liuc
Since your board doesn't have any low-level analog stuff, you may as
well just pour solid copper on the bottom side. You'll certainly also
need some signals on the bottom, so arrange for them to be generally
short so the ground plane isn't terribly chopped up by their
clearances, which it sounds like you've done. There's no advantage to
deliberately sectioning the ground plane into regions for different
functions and it can cause problems. The whole "star grounding" thing
is mostly popular superstition.
Pouring topside ground usually doesn't help, as all you wind up with
is a lot of slivers of copper not doing much except making
solder-bridge shorts and being confusing in general.
I could post a couple of pics to a.b.s.e.
John
N
Noway2
Liuc said:
Hi Noway2,
thanks again
Liuc
To estimate the bandwidth of a digital signal, you can use a concept
called the knee frequency. Roughly speaking, the knee frequency is the
point (frequency) at which the energy content of the signal starts to
drop off significantly. When you use the knee frequency concept, you
can't treat it as a hard and fast rule, but it can tell you if you are
in the clear, have something to consider, or have an outright problem.
If I remember correctly, the formula for the knee frequency that I use
is 0.5 / Trise (in ps), which is the formula I picked up from Dr.
Howard Johnson's book. There are probably other definitions. So if
your logic signal transisitions in 2ns (2000 ps) the Fknee is .5 / 2000
x10-12 or 250Mhz. This means that in order to avoid distorting the
signal edges, which can be critical in digital systems, you need to
make sure that your board is capable of handling an effective bandwidth
of 250Mhz as there will be significant engery content below this point.
To understand why there is energy content up to this point, think of a
Fourier representation of a digital pulse, which consists of a sum of
odd harmonics. The higher order harmonics are what gives the pulse its
sharp edges and hence the sharper the edges, the greater the
significance of the higher order harmonics.
These concepts also get into why when you probe a circuit that you
alter its behavior and why your o-scope isn't necessarilly giving you
an accurate picture. If you have a scope with a 100Mhz bandwidth you
will be missing the higher frequency effects.
Joel Kolstad
I believe Howard uses 0.35/Tr with the stated assumption of a Gaussian
frequency response in the measurement system. With contemporary instruments,
this is sometimes a little overly pessimistic... see, e.g.,
http://www.edn.com/article/CA263113.html
R
Rich Grise
My question is: how to use the ground plane? I've read plenty of threads
about it, but I didn't fully understand which is the best way to do. My
There aren't really any hard and fast rules - one thing to keep in mind is
current paths. Current always flows from the power supply through the load
(your circuit) and back. When you're laying out your power supplies and
parts, visualize which copper will have the current flowing from and to
the supply, and try to minimize the interaction between those current
flows for different supplies. I think this is the idea behind the "single
point" or "star" ground. If you watch your layout, that shouldn't be
necessary. Where is the current flowing is what you need to watch.
Also, I've always said you can't overcapacitate. 10uF or more at the power
entry point and a .1 ceramic (or more, depending on power/ground pins) at
each chip has always worked for me. :)
Good Luck!
Rich
L
Liuc
Hi again,
and thanks to eveybody who answered me: particulary to the posts about
signal bandwidth.
Now I don't have cleared all my doubts but I have things more clear.
thanks again,
Liuc
Noway2 ha scritto:
John Perry
I recall having seen this relation in Tektronix application notes
relating the bandwidth of a scope to the minimum distinguishable rise
time of that scope in the early 70's. The caveat about Gaussian
frequency response sounds familiar, too.
John Perry
