I have replaced a red LED (Vf = 1.9V) in a circuit powered by a 3V battery supply with a green LED (Vf = 3.3V). Both LEDs have a specified If of 20mA. As the batteries are Lithium, the voltage starts off slightly higher at approximately 3.4V when new.
The current through the green LED is much lower than the red one using the same current limit resistor. Is the green LED likely to cause the batteries to run flat faster? I assume that the lower current doesn't necessarily mean the overall power consumption is less since Vf is higher?
I needed the higher brightness hence, chose that particular green LED instead of one with a lower Vf.
