T
Tim Shoppa
Does anyone know if there exists, preferably on the web, a set of
graphs that show current vs voltage (or resistance vs RMS power or
any other equivalent) for common low-voltage bulbs?
I'm specifically looking for bulbs which may serve as a decent
AC current regulator. (Think "ballast tube" if you're old enough).
I've done some experiments with bulbs I had
laying around and they seem pretty good in the glow-dull-red region.
If anyone has any good rules-of-thumb (e.g. "run at 0.5 the rated
voltage and it'll pass sqrt(0.5) the rated current") I'll gladly
consider them
too as starting points. Above sample rule-of-thumb was chosen out
of think air and while it works for some bulbs it doesn't really help
me find points which will be good for constant current operation.
Worst case, I buy one of each kind of bulb from Mouser and make the
tests myself . But I'd prefer to find manufacturer's curves
on the web. I already checked Chicago Miniature and they didn't have
anything obvious.
Tim.
consider them
anything obvious.
Tim.
