graphics card VRAM replace
Discussion in 'Troubleshooting and Repair' started by kellogs, Jan 7, 2014.
  1. kellogs
    kellogs
    68
    Jan 7, 2014
    Hello,
    One (ore more) of my graphics card's VRAM has gone bad. Took out the card to only baffle on the VRAM chips being ... unreplaceable ? The VRAM seem to be facing up on both sides of the video card. I can't see their pins... Help!
    [​IMG]
    [​IMG]
  2. davenn
    davenn Moderator
    13,894
    1,969
    yeah they are all surface mount .... you are NOT going to replace them
    if its faulty you will have to buy a new card
    cheers
  3. kellogs
    kellogs
    68
    Jan 7, 2014
    damn.. all right, thanks !
  4. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    You could try bakeing the card at around 180celcius for about 3 minutes.
    If the problem is caused by cold (broken) solder then heating the card will do the trick.
    make sure you dont burn it hough.
    This trick worked on my laptops removable card.
    You have nothing to loose anyway right ?
  5. quantumtangles
    quantumtangles
    153
    3
    Dec 19, 2012
    When I see the magic smoke appear from a graphics card, I remove the cooling fan for parts (if it has one) and scrap the rest of it. This is from someone who collects old motherboards because I find them beautiful.
    Last time I wrecked a graphics card was when testing a second hand motherboard from ebay. I put the Motherboard linked to a power supply, monitor, mouse and keyboard, direct onto my kitchen table, desert fashion with no case. The graphics card moved ever so lightly....and shorted. Carelessness costs graphics cards :D
  6. kellogs
    kellogs
    68
    Jan 7, 2014
    Uhm, should I ? with al those electrolytic capacitors and who knows what other pieces of plastic that might not withstand this ?
    Anyway, how do I make it 180 deg in an old oven ?
    thanks
  7. (*steve*)
    25,500
    2,840
    Have you contemplated replacing the two capacitors that look like they have bulging tops?
    It is possible that this is the actual problem.
    I'd go for simple things before complex ones.
  8. kellogs
    kellogs
    68
    Jan 7, 2014
    eagle eyes! replaced them, worked a treat! thanks.
  9. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    Such temprature and short time should not harm any components. like i said it worked for me. Glad to hear that the caps worked for you..
    Theese electrolytic caps tend to go bad after a few years
