gps technical information
Discussion in 'Electronic Design' started by [email protected], Oct 6, 2007.
  1. Guest
    im in the need to design and develop a GPS receiver. but currently i
    dont have much technical knowledge in the subject. im looking for some
    internet resources where i can get a good understanding about the
    implementation side of it (with out much theory).
    hope someone can point some resources.
    thanks.
  2. Mook Johnson
    Mook Johnson Guest
    You do know that you can buy the modules for ~$50 each nowadays. even
    cheaper in Qtys.
    Check out Mighty GPS
    http://www.mightygps.com/oem/12channelgps.htm
    and DeluoElectronics
    http://www.deluoelectronics.com/category/19-GPS_OEM_Modules
  3. dalai lamah
    dalai lamah Guest
    Un bel giorno digitò:
    The first site to mention about do-it-yourself GPS is of course Clifford
    Kelley's:
    http://home.earthlink.net/~cwkelley/
    Googling for "open source GPS" gives you a lot of interesting results:
    http://www.google.com/search?q=open+source+gps
    Hmmm, that's gonna hurt. :)
  4. John Larkin
    John Larkin Guest
    As far as actually designing it, you may as well decide to climb
    Everest with no mountaineering training. You can probably get a
    reference design from one of the GPS chip-set makers, and basically
    copy it.
    John
  5. Guest
    This seems like great. please let me know if you have any experiance
    with this module.
    thank you for the info.
  6. What you need to look at is the NMEA protocol.
    There is zero sense in designing a GPS yourself,
    there are plenty of different modules on the market.
    Rene
  7. mook Johnson
    mook Johnson Guest
    I use a furono (Sp?) module that is bery similar but smaller. Very easy to
    use. supply power and read the signal with the serial port on any uC.
    The datasheet tells you which format. NMEA or binary. NMEA is good if you
    plan on switching between GPS suppliers as it is a standard protocol. It is
    "fluffy" though and is sent as ascii characters and you have to convert them
    to binary befoure you can do any math in the parameters (if you need to).
    Most modules also offer a binary mode that is already converted but eth
    binary nodes are usually not standard across brands.
  8. JosephKK
    JosephKK Guest
    posted to
    sci.electronics.design:
    And there you have it. You can use modules, or you can learn a
    shitpot of theory. Choose.
