M
MC
Alex said:Could someone recommend a gps module suitable for use
in embedded projects (pic and lpc21xx) , robotics and hooking up to a
(laptop/pc with windows and osx drivers).
Either 3V or 5V powered, ASCI output via rs232 or i2c or spi - (NMEA 0183)
and under 10cm by 10cm (5cm by 5cm or under would be better).
Start up time isn't a concern , up to a couple of minutes is fine
Quite a few out there, just wondering which ones people use more and
are fairly cheap , easy to use , reliable and rugged/robust.
I had a bit of a look at a few (first three look quite good)
UV40 - Laipac
TF30 - Laipac
Lassen iQ - Trimble
Rikaline GPS-23
Jupiter 12
Leadtek 9543
http://www.stepgps.com/products/trimble/lassenIQ.htm#physical
http://www.embedtronics.com/GPS/lassenSQ.html
UV40 , TF30 and Lassen listed here
http://www.sparkfun.com/shop/index.php?shop=1&cart=209810&cat=63&
Rikaline
http://www.modtronix.com/product_info.php?currency=AUD&cPath=61_63&products_id=139
Jupiter and leadtek GPS-9543 - bit pricy
http://www.tdc.co.uk/starter_packs/index.htm#gps9543
http://www.commlinx.com.au/
and
http://www.ja-gps.com.au/engines.html
