looking.
There are other similar OCXO and rubidium clock devices out there on
the surplus market. If you look at
http://www.leapsecond.com/, the
Z3801A-related stuff at
http://www.realhamradio.com/, and check out the
time-nuts mailing list (@febo.com) then you will see what's out there
for the picking.
The surplus-timing-source market isn't quite as plentiful as in the
year or two after the telecom crash, but there is at least a trickle.
Your 10^-8 second stability over 8 hours actually does require some
clarification: Do you need 10ns stability after 8 hours of unlock? At
that level OCXO stuff definitely isn't good enough and you'll have to
go to rubidium or cesium, and while rubidium stuff does show up at the
low k$ level new and less than that new, lucking across a cesium
reference for that little money will take extremely good fortune.
If you only meant 1 part out of 10^8, that would be 36 microseconds
over 8 hours, and that is easily done with an OCXO.
10ns precision over any number of hours is going to be pushing the edge
with a GPS-locked device, because these typically do not provide that
sort of precision at the PPS output. Typical $30-$50 range GPS modules
only guarantee under a microsecond of jitter (and typically achieve
100ns) on their PPS output. There are ones that go to the under-100ns
jitter guaranteed level but I don't know of any that promise to the
10ns level. (Some may deliver circa 10ns level under kid-glove
conditions although it's not guaranteed.)
If you need absolute time at the 10ns level from GPS then you need a
truly excellent survey, even then I think it's pushing the edge.
