GPIB 'Multidevice' API timeout
Discussion in 'Electronic Design' started by PaulH, Feb 28, 2007.
  1. PaulH
    PaulH Guest
    I'm using the GPIB 'multidevice' API for a project, but I find that
    the default command timeout is much too long to wait. Typically, using
    the 'traditional' API, I would set the timeout using the ibdev()
    command when I first initialize the GPIB device. But, since I'm using
    this 'multidevice' API, that isn't an option.
    Does anybody know a GPIB command other than ibdev() that sets the bus
    timeout?
    PaulH
  2. joseph2k
    joseph2k Guest
    Unless i mistaken that is a driver function, not a proper bus property. But
    it has been 20 years, do you have a current ieee-488 spec you can lend me?
  3. Nitro
    Nitro Guest
    Hi, Just adding my concurrance. ibtimo() and ibdev() are typically National
    Instruments driver API calls. ibtimo() is used for an open device usingan
    existing device handle. ( ibdev() is to open a device and you can set the
    initial values.)
    Remember the timeout value is an index not the acutal timeout. They have
    defines for the times (T10, T30 etc).
    What is the underlying driver that the 'multidevice API' is using?
    Bart
  4. Use the ibtmo command.
    Note: Have a look at the lookup table in the manual to get the desired timeout
    value.
  5. joseph2k
    joseph2k Guest
    Competitors APIs tended to be similar (a while ago, when i was fully in the
    game). I guess that it may be some kind of extension of the concept and
    bus command GET (Group Execute Trigger) intended to allow several
    instruments to acquire simultaneously. (in a sense a sloppy borrow from
    camac)
