Google wont help! 4 pin IC cannot find datasheet.
Discussion in 'Datasheets, Manuals and Component Identification' started by kingoftaurus, Jan 17, 2012.
  1. kingoftaurus
    kingoftaurus
    3
    Jan 17, 2012
    Hello, I have taken apart an old television and have found this 4 pin, integrated circuit on it, and no matter what kind of search on the internet I do, I just cannot find what it is.
    so im going to try to show you what it looks like so maybe you can help.
    PIN PF5001 PIN
    0001
    PIN K C . PIN
    Flip the chip over and there is a stamped K
    the K on the front of the chip is pretty fancy, eveything else is typed very clearly. and the " . " on the front is a white dot.
    I think i attached a pic of it.. dunno how that will work out
  2. (*steve*)
    25,480
    2,826
    I'd say it's either a bridge rectifier or an optocoupler.
    If you use a multimeter on a diode test range, you will find diodes across each of the 4 pins if it's a bridge rectifier, and across only 1 if its an optocoupler.
  3. kingoftaurus
    kingoftaurus
    3
    Jan 17, 2012
    Only across the side with the dot on it, red terminal on dot, black on the one just above it.
    So, optocoupler it is. So theres a little led inside. How interesting.
    http://en.wikipedia.org/wiki/Opto-isolator is where i read up on it. Seems useful.
    Wish i had a datasheet still, so i dont overload the poor thing. lol.
    Edit:
    Now that i know what it is, i found out exactly what it is...
    http://www.freelists.org/post/techassist/Sylvania-19-TV-May-2000-TVK199K-stormdead-FIX
