S
sert
Any suggestions?
Any suggestions?
Any suggestions?
Express PCB has a free schematic drawing program.
Its output is designed to be used in tandem with their PCB layout
program.
But you can still use it, even if you don't buy circuit boards.
http://www.expresspcb.com/ExpressPCBHtm/Free_cad_software.htm
-mpm
Scott Seidman said:Boy, are there any that just let you DRAW circuits, without having to
enter detailed parts and footprints in a library, and aren't packaged
around creating a layout? I've been looking for a good tool like that to
help with creating slides FOR YEARS
What point is there to creating a "drawing" of a schematic if it won't
netlist??
Frankly, the apps others have mentioned are less of a dead endmpm said:Express PCB has a free schematic drawing program.
It would be nice if those who advocate for this CRIPPLEWARE[...]you can still use it, even if you don't buy circuit boards.
Those who advocate for EAGLE (properly written in all caps),Tim said:Eagle isn't open source, but there's a free trial version
that'll let you do A size schematics and 3 x 4 inch boards.
Upgrades to "paid" versions are inexpensive,
and it's a currently supported project.
This is where Joerg usually mentions *no hierarchacal structure*.I use it here. I wouldn't want to use it on a board that needed
10 C-sized pages for the schematic, but for little things it's great.
Scott said:Boy, are there any that just let you DRAW circuits, without having to
should the OP decide to produce actual hardware.
It would be nice if those who advocate for CRIPPLEWAREhttp://groups.google.com/group/comp.arch.embedded/browse_frm/thread/4...would include instructions for how to print from it (disabled in the
app)
--or at least a link which describes the hoops you have to jump thru.
would mention that Gerbers must be PURCHASED
from the fab houses which distribute this lock-in-ware.
Having to learn yet another app/interface
when you *do* want to produce PCBs
(using a general-purpose **non-locked** ECAD)
makes learning/using these CRIPPLEWARE apps look silly.
Yes ! Try Open Office. www.openoffice.org It has a drawing feature.Scott said:Boy, are there any that just let you DRAW circuits, without having to
to help with creating slides FOR YEARS
Baron said:Yes ! Try Open Office. www.openoffice.org It has a drawing feature.
Joerg said:Once I got a schematic from a client that was scanned in
and they needed change recommendations pit stop style,
right now, no time to re-draw it in CAD.
So I used, <gasp>, MS-Paint. Worked! Once you get the hang of
fast copy&paste in there it's a breeze.
sert said:Any suggestions?
I like (and use) the old original MicroSim PSpice Schematics. Been
using it since it first appeared, gawd knows how many years now, to
make ASIC's... no problems.
to
Jim Thompson said:But if you're into generalities how many "library" parts can there be
to "build"...
NPN, PNP, SCR, TRIAC, R, C, L, OpAmp, Comparator, NMOS, PMOS, and
(most important ;-) LED ??
